Zum Hauptinhalt wechseln
Insignia NS-CLLT01 Button Replacement
Was du brauchst
  1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: Schritt 1, Bild 1 von 2 Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: Schritt 1, Bild 2 von 2
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. Insignia NS-CLLT01 Button Replacement: Schritt 2, Bild 1 von 3 Insignia NS-CLLT01 Button Replacement: Schritt 2, Bild 2 von 3 Insignia NS-CLLT01 Button Replacement: Schritt 2, Bild 3 von 3
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Insignia NS-CLLT01 Button Replacement: Schritt 3, Bild 1 von 1
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Insignia NS-CLLT01 Button Replacement: Schritt 4, Bild 1 von 1
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Insignia NS-CLLT01 Button Replacement: Schritt 5, Bild 1 von 3 Insignia NS-CLLT01 Button Replacement: Schritt 5, Bild 2 von 3 Insignia NS-CLLT01 Button Replacement: Schritt 5, Bild 3 von 3
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
  6. Insignia NS-CLLT01 Button Replacement, Button: Schritt 6, Bild 1 von 1
    • Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
  7. Insignia NS-CLLT01 Button Replacement: Schritt 7, Bild 1 von 1
    • Lift the circuit board from the device.
  8. Insignia NS-CLLT01 Button Replacement: Schritt 8, Bild 1 von 2 Insignia NS-CLLT01 Button Replacement: Schritt 8, Bild 2 von 2
    • Detach the circuit board from the rest of the clock by gripping the sides of the white ribbon cable connector on the left-hand side of the board and pulling it straight off. You may need to use tweezers to grip the connector.
  9. Insignia NS-CLLT01 Button Replacement: Schritt 9, Bild 1 von 3 Insignia NS-CLLT01 Button Replacement: Schritt 9, Bild 2 von 3 Insignia NS-CLLT01 Button Replacement: Schritt 9, Bild 3 von 3
    • Use this soldering guide to remove and replace any buttons that were not working.
    • The buttons will be labeled on the top of the circuit board, and you will be working with the corresponding connections on the back.
Abschluss
Baylor, Team 6-9, Williams Fall 2015 Mitglied von Baylor, Team 6-9, Williams Fall 2015
BU-WILLIAMS-F15S6G9
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 290
