Einleitung
If the bottom panel is damaged or needs to be moved to reach another component of the laptop this is a guide to remove it.
Was du brauchst
Flip the computer so the bottom is facing up with the battery away from you.
Slide the battery switch to the left until the battery unlatches from the base of the laptop.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
