Einleitung
Components below the laptop need to be removed before you can detach the keyboard. This is a guide to remove your laptop's keyboard.
Was du brauchst
Flip the computer so the bottom is facing up with the battery away from you.
Slide the battery switch to the left until the battery unlatches from the base of the laptop.
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Using a PH 00 screwdriver, remove the screw located next to the wireless card.
Insert a plastic spudger or similar pry tool, beneath the keyboard, near the "insert" key, and pop the keyboard up from the laptop.
Starting at the opening you just created, run your fingers around the outside of the keyboard separating it from the rest of the computer.
Slightly angle the keyboard back so the ribbon connector underneath it is visible.
Remove the ribbon cable by using your fingers to pull up and away from the connector.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
