Zum Hauptinhalt wechseln
Insignia Flex 8 NS-15AT08 Battery Replacement
Was du brauchst
  1. Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: Schritt 1, Bild 1 von 2 Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Battery Replacement: Schritt 2, Bild 1 von 2 Insignia Flex 8 NS-15AT08 Battery Replacement: Schritt 2, Bild 2 von 2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Wedge a plastic opening tool in between the male, black module and female, white module to disconnect the wires module from the circuit board.
  4. Insignia Flex 8 NS-15AT08 Battery Replacement: Schritt 4, Bild 1 von 3 Insignia Flex 8 NS-15AT08 Battery Replacement: Schritt 4, Bild 2 von 3 Insignia Flex 8 NS-15AT08 Battery Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to pry the battery from the circuit board by wedging it around the perimeter of the battery.
  5. Insignia Flex 8 NS-15AT08 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery from the circuit board by lifting it with the spudger or finger.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Jeremy Anaya
316 Reputation
2 Anleitungen geschrieben
Baylor, Team 6-7, Williams Fall 2015 Mitglied von Baylor, Team 6-7, Williams Fall 2015
BU-WILLIAMS-F15S6G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,904
