Zum Hauptinhalt wechseln
Insignia NS-CLLT01 Motherboard Removal
Was du brauchst
  1. Insignia NS-CLLT01 Motherboard Removal, Motherboard: Schritt 1, Bild 1 von 2 Insignia NS-CLLT01 Motherboard Removal, Motherboard: Schritt 1, Bild 2 von 2
    • Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
  2. Insignia NS-CLLT01 Motherboard Removal: Schritt 2, Bild 1 von 2 Insignia NS-CLLT01 Motherboard Removal: Schritt 2, Bild 2 von 2
    • Remove the white ribbon connector that connects the central circuit board to the circuit board attached to the top of the clock by gripping it on both sides and pulling it straight away from the board.
  3. Insignia NS-CLLT01 Motherboard Removal: Schritt 3, Bild 1 von 1
    • Unscrew the two 10mm screws from the bottom circuit board.
  4. Insignia NS-CLLT01 Motherboard Removal: Schritt 4, Bild 1 von 3 Insignia NS-CLLT01 Motherboard Removal: Schritt 4, Bild 2 von 3 Insignia NS-CLLT01 Motherboard Removal: Schritt 4, Bild 3 von 3
    • Use the narrow end of a plastic spudger to pull back the clip in the center of the board.
    • At the same time, pry the circuit board up by wedging another spudger into the top left-hand corner of the board and working it along the back, pushing the edge of the board away from the back of the clock.
    • The black radio antenna, which is attached to the board and comes out of the back of the clock, will need to be pushed into the clock from the outside as the board is lifted up.
  5. Insignia NS-CLLT01 Motherboard Removal: Schritt 5, Bild 1 von 1
    • Once the ports on the back of the circuit board are displaced and resting against the back of the clock, use a pair of tweezers to lift the circuit board up off of the bottom of the clock, continuing to feed the radio antenna through the side of the clock as the board lifts up.
  6. Insignia NS-CLLT01 Motherboard Removal: Schritt 6, Bild 1 von 1
    • Pull the radio antenna the rest of the way through the side of the clock.
  7. Insignia NS-CLLT01 Motherboard Removal: Schritt 7, Bild 1 von 1
    • Turn the circuit board over.
    • Disconnect the two white connectors on the bottom of the circuit board by gripping the sides of each connector and pulling straight out.
Ziellinie
Baylor, Team 6-9, Williams Fall 2015 Mitglied von Baylor, Team 6-9, Williams Fall 2015
BU-WILLIAMS-F15S6G9
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 219
