Zum Hauptinhalt wechseln
Insignia NS-CLLT01 Top Casing Removal
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Insignia NS-CLLT01 Top Casing Removal, Insignia NS-CLLT01 Top Casing Removal: Schritt 1, Bild 1 von 2 Insignia NS-CLLT01 Top Casing Removal, Insignia NS-CLLT01 Top Casing Removal: Schritt 1, Bild 2 von 2
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. Insignia NS-CLLT01 Top Casing Removal: Schritt 2, Bild 1 von 3 Insignia NS-CLLT01 Top Casing Removal: Schritt 2, Bild 2 von 3 Insignia NS-CLLT01 Top Casing Removal: Schritt 2, Bild 3 von 3
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Insignia NS-CLLT01 Top Casing Removal: Schritt 3, Bild 1 von 1
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Insignia NS-CLLT01 Top Casing Removal: Schritt 4, Bild 1 von 1
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Insignia NS-CLLT01 Top Casing Removal: Schritt 5, Bild 1 von 3 Insignia NS-CLLT01 Top Casing Removal: Schritt 5, Bild 2 von 3 Insignia NS-CLLT01 Top Casing Removal: Schritt 5, Bild 3 von 3
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
Ziellinie
Baylor, Team 6-9, Williams Fall 2015 Mitglied von Baylor, Team 6-9, Williams Fall 2015
BU-WILLIAMS-F15S6G9
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 49
