Zum Hauptinhalt wechseln
LG VS810 Screen Replacement
Was du brauchst
    • Remove the back cover
    • Remove the battery , SIM card, and SD card
    • Unscrew the 8 screws using a Phillips (PH#00) screwdriver
    • Using a plastic opening tool , once again pry up on the edges of the plastic back cover.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced
    • Gently disconect the screen cable using a spudger.
    • Using the spudger, pry the motherboard away from the screen assembly.
    • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
    • Continue to heat and separate until the screen comes completely apart from the rest of the phone using plastic tools
    • The phone will be extremely hot. Avoid direct contact with metal pieces.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
[deleted]
398 Reputation
1 Anleitung geschrieben
Ein Kommentar
Pls help how can I fix lg-k120e screen
drammehoumar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 25
Insgesamt: 4,370
