Einleitung
Upgrade the RAM in your laptop.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:T5 Torx Screwdriver$9.99
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
Remove the bottom panel from the body of the laptop.
Set aside the bottom panel.
Push away the RAM retaining arms from the RAM chip.
Remove the RAM chip completely.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
