Einleitung
If you're having scanning issues as a result of a faulty sensor bar, this is where you will want to begin.
To replace the sensor bar in the Canon CanoScan N670U, you must:
- Remove the two plastic bars that hold the glass scanner bed.
- Set aside the scanner bed.
- Loosen the belt from the plastic hook.
- Remove the sensor bar for replacement.
Was du brauchst
Open up your Canon CanoScan N670U to an upright position.
Turn your device so that you're facing the long side of the Canon CanoScan N670U.
Locate the small crevice between the plastic components of the scanner bed and the scanner base.
Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
Locate the small plug where the white strip of cable is connected to.
Unfurl the cable strip if it's tucked in.
Locate the small metal spring behind the front buttons of the Canon CanoScan N670U.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
