Zum Hauptinhalt wechseln
DigiLand DL1010Q Rear Case Replacement
Was du brauchst
  1. DigiLand DL1010Q Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Rear Case Replacement: Schritt 2, Bild 1 von 2 DigiLand DL1010Q Rear Case Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 511
