Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 7.0 Camera Replacement
Was du brauchst
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 2, Bild 1 von 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 5, Bild 2 von 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Camera Replacement: Schritt 6, Bild 2 von 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: Schritt 7, Bild 1 von 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: Schritt 7, Bild 2 von 3 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: Schritt 7, Bild 3 von 3
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Aubrey Goodwin
2.700 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 1-3, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Mitglieder
12 Anleitungen geschrieben
3 Kommentare
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Antwort
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Antwort
टॅब पार्ट खरेदी करना है मुझको
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 4,274
