Zum Hauptinhalt wechseln
Nikon Coolpix S5200 LCD Screen Replacement
Was du brauchst
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 3 von 3
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix S5200 LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
Abschluss
Andy Powers
391 Reputation
3 Anleitungen geschrieben
University of Alabama, Team 1-2, Sydow campbell Fall 2015 Mitglied von University of Alabama, Team 1-2, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G2
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 1,019
