Zum Hauptinhalt wechseln
HP Envy 23-d060qd TouchSmart Speaker Replacement
Was du brauchst
  1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 3, Bild 1 von 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: Schritt 4, Bild 1 von 1
    • Remove the receiver for the keyboard and mouse with your hands.
  5. HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 5, Bild 1 von 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  6. HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 6, Bild 1 von 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  7. HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 7, Bild 1 von 2 HP Envy 23-d060qd TouchSmart Speaker Replacement: Schritt 7, Bild 2 von 2
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
Abschluss
Zachary Dicks
1.117 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 5-10, Maness Fall 2015 Mitglied von Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
where to get the replacement speaker???????
Clovis Young - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,385
