Zum Hauptinhalt wechseln
HP EliteOne 800 G1 Power Supply Replacement
Was du brauchst
  1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: Schritt 1, Bild 1 von 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: Schritt 1, Bild 2 von 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: Schritt 1, Bild 3 von 3
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: Schritt 2, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: Schritt 2, Bild 2 von 2
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Power Supply Replacement: Schritt 3, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement: Schritt 3, Bild 2 von 2
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Power Supply Replacement: Schritt 4, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement: Schritt 4, Bild 2 von 2
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: Schritt 5, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement, Power Supply: Schritt 5, Bild 2 von 2
    • Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
    • Lift up on the VESA mount cover to remove it.
  6. HP EliteOne 800 G1 Power Supply Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the power supply's black and yellow cable from the motherboard.
  7. HP EliteOne 800 G1 Power Supply Replacement: Schritt 7, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement: Schritt 7, Bild 2 von 2
    • Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
    • Lift the power supply from the case to remove it.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Michael Ewing
1.071 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 1-24, Maness Fall 2015 Mitglied von Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 24
Letzte 30 Tage: 51
Insgesamt: 5,299
