Zum Hauptinhalt wechseln
Asus Zenbook UX32VD GPU Fan Replacement
Was du brauchst
  1. Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: Schritt 1, Bild 1 von 3 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: Schritt 1, Bild 2 von 3 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    T5 Torx Screwdriver
    $9.99
    Kaufen
  2. Asus Zenbook UX32VD GPU Fan Replacement: Schritt 2, Bild 1 von 3 Asus Zenbook UX32VD GPU Fan Replacement: Schritt 2, Bild 2 von 3 Asus Zenbook UX32VD GPU Fan Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD GPU Fan Replacement, Fan: Schritt 3, Bild 1 von 3 Asus Zenbook UX32VD GPU Fan Replacement, Fan: Schritt 3, Bild 2 von 3 Asus Zenbook UX32VD GPU Fan Replacement, Fan: Schritt 3, Bild 3 von 3
    Spudger
    $2.99
    Kaufen
    • Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
    • Be sure to pry up on the hinged retaining flap, not the connector itself.
    • Remove the metallic ribbon cable from the connector .
    • No force is needed to remove or insert the cable.
  4. Asus Zenbook UX32VD GPU Fan Replacement: Schritt 4, Bild 1 von 3 Asus Zenbook UX32VD GPU Fan Replacement: Schritt 4, Bild 2 von 3 Asus Zenbook UX32VD GPU Fan Replacement: Schritt 4, Bild 3 von 3
    Phillips #0 Screwdriver
    $5.49
    Kaufen
  5. Asus Zenbook UX32VD GPU Fan Replacement: Schritt 5, Bild 1 von 3 Asus Zenbook UX32VD GPU Fan Replacement: Schritt 5, Bild 2 von 3 Asus Zenbook UX32VD GPU Fan Replacement: Schritt 5, Bild 3 von 3
    • Unplug the bundled cable connector.
    • Move the fan as shown in the first picture to better access the connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD GPU Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the fan completely.
Abschluss
CSU Fullerton, Team 2-2, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 2,195
