Zum Hauptinhalt wechseln
Lenovo Thinkpad x230 SSD/Hard Drive Replacement
Was du brauchst
Einführungsvideo
  1. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Preparations: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Locate the battery: Schritt 2, Bild 1 von 1
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Unlock the left switch: Schritt 3, Bild 1 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Unlock the left switch: Schritt 3, Bild 2 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Unlock the left switch: Schritt 3, Bild 3 von 3
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove the battery: Schritt 4, Bild 1 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove the battery: Schritt 4, Bild 2 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove the battery: Schritt 4, Bild 3 von 3
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
  5. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Locate the hard drive enclosure: Schritt 5, Bild 1 von 1
    • Locate the hard drive enclosure (marked by the red rectangle).
  6. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove enclosure: Schritt 6, Bild 1 von 2 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove enclosure: Schritt 6, Bild 2 von 2
    • Use a small Phillips screwdriver to unscrew the single screw that holds down the hard drive enclosure cover.
    • The screw is designed to remain within the plastic cover. Don't worry about extracting it completely.
    • Carefully remove the hard drive enclosure cover.
  7. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove SSD/hard drive: Schritt 7, Bild 1 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove SSD/hard drive: Schritt 7, Bild 2 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove SSD/hard drive: Schritt 7, Bild 3 von 3
    • Gently pull the black pull tab out from above the hard drive. Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
    • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
  8. Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove plastic rails: Schritt 8, Bild 1 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove plastic rails: Schritt 8, Bild 2 von 3 Lenovo Thinkpad x230 SSD/Hard Drive Replacement, Remove plastic rails: Schritt 8, Bild 3 von 3
    • Remove the plastic rails from the old SSD/hard drive and place them on the new SSD/hard drive.
Abschluss
21 weitere Nutzer:innen haben diese Anleitung absolviert.
Johannes
1.061 Reputation
3 Anleitungen geschrieben
15 Kommentare
Hy sir
i have one question about this laptop lenovo x230 thinkpad i have internald SSD 128 i want to increase in 500GB any body can tell me
which size of ssd possible for lenovo think pad x230 and which company thanks
nisarahmed_980 - Antwort
It looks to be a 2.5 in hard drive/solid state drive.
Nageek Gamer -
500GB will work fine.
John X - Antwort
500 GB will work fine.
John X - Antwort
Hi,
I have an lenovo thinkpad x230t convertible laptop, which I want to upgrade with a ssd what are the specifications I should be looking for in a ssd so that it would be compatible with my laptop,
Thanks in advance
adwaitgaikwad - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 31
Letzte 30 Tage: 105
Insgesamt: 32,431
