Zum Hauptinhalt wechseln
LG G Pad 7.0 Display Assembly Replacement
Was du brauchst
  1. LG G Pad 7.0 Display Assembly Replacement, Front Panel: Schritt 1, Bild 1 von 2 LG G Pad 7.0 Display Assembly Replacement, Front Panel: Schritt 1, Bild 2 von 2
    • The screen assembly is secured to the plastic backing with clips.Insert the plastic opening tool between the screen and plastic.
    • Carefully work your way around the device making sure not to go too deep damaging any eternal components, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Display Assembly Replacement, Connectors: Schritt 2, Bild 1 von 3 LG G Pad 7.0 Display Assembly Replacement, Connectors: Schritt 2, Bild 2 von 3 LG G Pad 7.0 Display Assembly Replacement, Connectors: Schritt 2, Bild 3 von 3
    • Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
    • You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
    • Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
  3. LG G Pad 7.0 Display Assembly Replacement, Logic Board: Schritt 3, Bild 1 von 2 LG G Pad 7.0 Display Assembly Replacement, Logic Board: Schritt 3, Bild 2 von 2
    • Remove the 7 screws marked in red that are securing the logic board to the case.
    • Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Very carefully remove the logic board after the screws have been removed
  4. LG G Pad 7.0 Display Assembly Replacement: Schritt 4, Bild 1 von 3 LG G Pad 7.0 Display Assembly Replacement: Schritt 4, Bild 2 von 3 LG G Pad 7.0 Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove the two screw marked in red.
    • Using the tweezers , gently pull out the metal bracket that holds the charging port in place.
    • Carefully pull out the ribbon connector in orange.
    • Remove the one screw that holds the speaker in place.
    • Slowly pull out the speaker.
  5. LG G Pad 7.0 Display Assembly Replacement: Schritt 5, Bild 1 von 2 LG G Pad 7.0 Display Assembly Replacement: Schritt 5, Bild 2 von 2
    • Insert your new mother board with the 7 screws
    • Reconnect all the connectors marked in red back to the mother board.
    • Flip your device. Begin to heat the adhesive holding the display to loosen from the plastic midframe.
    • Slowly work your way around removing the display from the midframe with a razor blade.
    • When inserting your razor make sure to not go in too deep. This will prevent the razor from cutting into any vital components.
    • Take your new display and apply the adhesive or double side tape to adhere to the plastic frame.
    • For best results use the biggest size that will fit the frame without overlapping with the lcd part.
    • You can find displays that already come with a new frame and/or adhesive
    • Press firmly all around after installing the new display. Allowing the adhesive/double side tape to have a better bond.
Abschluss
Give some time for the adhesive to dry completely all the way around. When reassembling your device just follow the steps above in reveres order.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
echow2001
2.117 Reputation
4 Anleitungen geschrieben
LGBTQ Technicians Mitglied von LGBTQ Technicians
Community
14 Mitglieder
23 Anleitungen geschrieben
6 Kommentare
Thanks so very much for a very helpful guide. YOU rock dude!!!
Tara Davis - Antwort
This doesn’t make sense.  guide is to replace display, Step 5 is “Insert new motherboard”???
Then no pictures for steps 6 and 7, are they to be done with motherboard in place or what?
Matt McMains - Antwort
What does your replacement display look like? does it include the plastic frame? “New motherboard” incorrectly assumes youre replacing the motherboard, if youre doing a screen, just re insert your old one.
echow2001 -
There should be a different guide for the motherboard. Step 5 is super confusing.
Samuel Enrique Gonzalez - Antwort
I totally agree. You should have one guide for just the screen replacement and one for motherboard replacement otherwise anyone following step by step to do either task will be doing unnecessary steps. It would clear up a lot of confusion if there were two separate guides.
Forrest Faulkner - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 4,886
