Zum Hauptinhalt wechseln
Disassembling Samsung SyncMaster 205BW Monitor
Was du brauchst
  1. Disassembling Samsung SyncMaster 205BW Monitor, Disassembling Samsung SyncMaster 205BW Monitor: Schritt 1, Bild 1 von 1
    • Back of the monitor. Remove the two screws at the top of the stand.
  2. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 2, Bild 1 von 1
    • Stand and monitor body now separated.
  3. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 3, Bild 1 von 1
    • Front of monitor body. Push on the silver edge to unhook it from the panel.
  4. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 4, Bild 1 von 1
    • Silver edge cover unlocked. Note that a cable connects to the body. Hold the panel and remove the black cover at the back. You can then disconnect the cable.
  5. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 5, Bild 1 von 1
    • Silver edge removed and placed under the body with metal back. Black cover removed. The front panel cable connects to the bottom right of the body. Remove it. Remove the metal cover on top right by pulling it slightly on the edge at the top. This allows the two hooks on the slanting edge of the metal bracket to be unhooked.
  6. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 6, Bild 1 von 1
    • Remove the cover on the right to reveal two cables with four connectors. There is also a connector under the air holes which is now shown above the bracket with words "LVDS". Remove them all to free the metal bracket with the circuit boards from the panel.
  7. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 7, Bild 1 von 1
    • The metal bracket with circuit boards. The smaller circuit board: * two screws (bottom left, bottom right) * four screw extenders at the sides of the connectors The larger circuit board: * two black screws (bottom left, top middle) * one silver screw with washer that holds a metal strip and circuit board (top left)
  8. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 8, Bild 1 von 1
    • Circuit board with unfastened screws pointing to the holes they were in.
  9. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 9, Bild 1 von 1
    • Disassembled pieces.
  10. Disassembling Samsung SyncMaster 205BW Monitor: Schritt 10, Bild 1 von 1
    • Circuit boards zoomed in.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
YIP Chi Lap
282 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 35
Insgesamt: 8,073
