Zum Hauptinhalt wechseln
HP Pavilion dv1000 RAM Replacement
Was du brauchst
  1. HP Pavilion dv1000 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 RAM Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 RAM Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv1000 RAM Replacement: Schritt 3, Bild 2 von 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 RAM Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv1000 RAM Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv1000 RAM Replacement: Schritt 4, Bild 3 von 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • Locate RAM access door on the bottom side of the laptop.
  6. HP Pavilion dv1000 RAM Replacement: Schritt 6, Bild 1 von 3 HP Pavilion dv1000 RAM Replacement: Schritt 6, Bild 2 von 3 HP Pavilion dv1000 RAM Replacement: Schritt 6, Bild 3 von 3
    • Locate the two screws holding down the RAM access cover
    • Unscrew the two screws with a size 00 Philips screwdriver.
    • Note: The screws do not detach from the cover.
  7. HP Pavilion dv1000 RAM Replacement: Schritt 7, Bild 1 von 2 HP Pavilion dv1000 RAM Replacement: Schritt 7, Bild 2 von 2
    • Lift up on the screw side of the RAM access cover to remove it.
  8. HP Pavilion dv1000 RAM Replacement: Schritt 8, Bild 1 von 2 HP Pavilion dv1000 RAM Replacement: Schritt 8, Bild 2 von 2
    • Gently pull apart the metal tabs located on both sides of the stick of RAM.
    • The RAM stick should tilt upwards.
  9. HP Pavilion dv1000 RAM Replacement: Schritt 9, Bild 1 von 1
    • Gently lift the the RAM up and out of its seat.
  10. HP Pavilion dv1000 RAM Replacement: Schritt 10, Bild 1 von 1
    • Repeat the previous two steps for the remaining stick of RAM.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 10-37, Forte Spring 2011 Mitglied von Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - Antwort
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 8,892
