Einleitung
If you are having trouble with your USB connection you might need to replace the USB port. This is a guide for replacing the USB connection port on the Hero4 Black.
Was du brauchst
First, you will have to remove the faceplate by carefully using the spudger around the edge to loosen the clips.
After loosening the clips on the edge, pull the faceplate off.
Now, you will need to take a PH000 Philips head screwdriver and remove the 4 corner screws.
Now, you will need to remove the camera and boards from the black plastic housing. You may use any tool that will do the job. My group found out, if you use the plastic tool to remove the boards and camera, that it would assist you with the removal.
Remove the ribbon strip by carefully pulling on it. It should slide out of its connection.
When you push down on the three wires that are connected to the clip. The clip will disconnect from the motherboard.
Take yourPH000 Philips head screwdriver to remove the four screws outlined in red.
Once the screws are removed. Gently remove the board and as you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
Take your PH000 Philips head screwdriver and remove the three screws that are outlined in red.
Just like before, gently pull up on the ribbon strip to remove the connector from the motherboard.
Remove the two screws to remove the riser that is being held in place by the screws.
At the top of the ribbon strip, there is a black clip that will need to be popped up.
Gently, grab the ribbon with a pair of tweezers to disconnect the ribbon from the connecter.
Now, the motherboard can be removed. Due to the USB connector being soldered to the motherboard, the entire board will need to be replaced.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
