Zum Hauptinhalt wechseln
BlackBerry Curve 8520 Motherboard Replacement
Was du brauchst
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 2 BlackBerry Curve 8520 Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 2 BlackBerry Curve 8520 Motherboard Replacement, Battery: Schritt 2, Bild 2 von 2
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: Schritt 3, Bild 1 von 2 BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: Schritt 3, Bild 2 von 2
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: Schritt 4, Bild 1 von 2 BlackBerry Curve 8520 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: Schritt 5, Bild 1 von 3 BlackBerry Curve 8520 Motherboard Replacement: Schritt 5, Bild 2 von 3 BlackBerry Curve 8520 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: Schritt 6, Bild 1 von 3 BlackBerry Curve 8520 Motherboard Replacement: Schritt 6, Bild 2 von 3 BlackBerry Curve 8520 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 BlackBerry Curve 8520 Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: Schritt 8, Bild 1 von 2 BlackBerry Curve 8520 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
Abschluss
32 weitere Nutzer:innen haben diese Anleitung absolviert.
Matt
1.722 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 9-62, Walters Spring 2011 Mitglied von Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Mitglieder
Ein Kommentar
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 36,784
