Zum Hauptinhalt wechseln
Removing the Apple Cinema Display M8149 Display Hinge
Was du brauchst
  1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: Schritt 1, Bild 1 von 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: Schritt 1, Bild 2 von 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: Schritt 1, Bild 3 von 3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Removing the Apple Cinema Display M8149 Display Hinge: Schritt 2, Bild 1 von 3 Removing the Apple Cinema Display M8149 Display Hinge: Schritt 2, Bild 2 von 3 Removing the Apple Cinema Display M8149 Display Hinge: Schritt 2, Bild 3 von 3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Removing the Apple Cinema Display M8149 Display Hinge: Schritt 3, Bild 1 von 2 Removing the Apple Cinema Display M8149 Display Hinge: Schritt 3, Bild 2 von 2
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
  4. Removing the Apple Cinema Display M8149 Display Hinge: Schritt 4, Bild 1 von 3 Removing the Apple Cinema Display M8149 Display Hinge: Schritt 4, Bild 2 von 3 Removing the Apple Cinema Display M8149 Display Hinge: Schritt 4, Bild 3 von 3
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 10-41, Forte Spring 2011 Mitglied von Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
in 2023 where can I get a replacement stand?
Mitch Leung - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 7,806
