Zum Hauptinhalt wechseln
PowerBook 3400 M3553 Keyboard Replacement
Was du brauchst
  1. PowerBook 3400 M3553 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Keyboard Replacement: Schritt 2, Bild 1 von 2 PowerBook 3400 M3553 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Keyboard Replacement: Schritt 4, Bild 1 von 3 PowerBook 3400 M3553 Keyboard Replacement: Schritt 4, Bild 2 von 3 PowerBook 3400 M3553 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Keyboard Replacement: Schritt 5, Bild 1 von 2 PowerBook 3400 M3553 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 24-59, Amido Spring 2011 Mitglied von Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 2,182
