Zum Hauptinhalt wechseln
APS Tech 101629 Exhaust Fan Replacement
Was du brauchst
  1. APS Tech 101629 Exhaust Fan Replacement, External Casing: Schritt 1, Bild 1 von 3 APS Tech 101629 Exhaust Fan Replacement, External Casing: Schritt 1, Bild 2 von 3 APS Tech 101629 Exhaust Fan Replacement, External Casing: Schritt 1, Bild 3 von 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Exhaust Fan Replacement: Schritt 2, Bild 1 von 2 APS Tech 101629 Exhaust Fan Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Exhaust Fan Replacement: Schritt 3, Bild 1 von 2 APS Tech 101629 Exhaust Fan Replacement: Schritt 3, Bild 2 von 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Exhaust Fan Replacement: Schritt 4, Bild 1 von 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Exhaust Fan Replacement: Schritt 5, Bild 1 von 2 APS Tech 101629 Exhaust Fan Replacement: Schritt 5, Bild 2 von 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: Schritt 6, Bild 1 von 2 APS Tech 101629 Exhaust Fan Replacement, Channel Switch: Schritt 6, Bild 2 von 2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Exhaust Fan Replacement: Schritt 7, Bild 1 von 3 APS Tech 101629 Exhaust Fan Replacement: Schritt 7, Bild 2 von 3 APS Tech 101629 Exhaust Fan Replacement: Schritt 7, Bild 3 von 3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
  8. APS Tech 101629 Exhaust Fan Replacement, Power Switch: Schritt 8, Bild 1 von 2 APS Tech 101629 Exhaust Fan Replacement, Power Switch: Schritt 8, Bild 2 von 2
    • Depress 2 pressure holds on each side of the power switch.
    • Press out the back of the device.
  9. APS Tech 101629 Exhaust Fan Replacement: Schritt 9, Bild 1 von 2 APS Tech 101629 Exhaust Fan Replacement: Schritt 9, Bild 2 von 2
    • Remove all four 4 connections from the power switch.
    • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
    • These are very hard to get off, use patience and wiggling.
  10. APS Tech 101629 Exhaust Fan Replacement, Exhaust Fan: Schritt 10, Bild 1 von 1
    • Remove temperature guage.
  11. APS Tech 101629 Exhaust Fan Replacement: Schritt 11, Bild 1 von 3 APS Tech 101629 Exhaust Fan Replacement: Schritt 11, Bild 2 von 3 APS Tech 101629 Exhaust Fan Replacement: Schritt 11, Bild 3 von 3
    • Move the exhaust fan out of the way so you can access its control cord.
    • Use the spudger to depress the hold on the fan cord.
    • Gently pull fan cord from connection and remove fan completely.
Abschluss
Cal Poly, Team 24-60, Amido Spring 2011 Mitglied von Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 665
