Zum Hauptinhalt wechseln
Nikon Coolpix S51c Back Cover Replacement
Was du brauchst
  1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 2 Nikon Coolpix S51c Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Nikon Coolpix S51c Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Back Cover Replacement: Schritt 5, Bild 1 von 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan
155 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 18-24, Garner Spring 2011 Mitglied von Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,311
