Zum Hauptinhalt wechseln
Sony VAIO PCG-933A Keyboard Replacement
Was du brauchst
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Sony VAIO PCG-933A Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Keyboard Replacement: Schritt 2, Bild 1 von 3 Sony VAIO PCG-933A Keyboard Replacement: Schritt 2, Bild 2 von 3 Sony VAIO PCG-933A Keyboard Replacement: Schritt 2, Bild 3 von 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A Keyboard Replacement: Schritt 4, Bild 1 von 2 Sony VAIO PCG-933A Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A Keyboard Replacement: Schritt 6, Bild 1 von 3 Sony VAIO PCG-933A Keyboard Replacement: Schritt 6, Bild 2 von 3 Sony VAIO PCG-933A Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A Keyboard Replacement: Schritt 7, Bild 1 von 3 Sony VAIO PCG-933A Keyboard Replacement: Schritt 7, Bild 2 von 3 Sony VAIO PCG-933A Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
Abschluss
Sara Lillard
165 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 12-36, Maness Spring 2011 Mitglied von Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 1,785
