Einleitung
This guide will show you how to access, remove, and replace the LCD screen. The process is safe and uncomplicated.
Was du brauchst
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
