Zum Hauptinhalt wechseln
Apple Powerbook 520/540 General Disassembly
Was du brauchst
  1. Apple Powerbook 520/540 General Disassembly, Case: Schritt 1, Bild 1 von 2 Apple Powerbook 520/540 General Disassembly, Case: Schritt 1, Bild 2 von 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: Schritt 2, Bild 1 von 1
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Apple Powerbook 520/540 General Disassembly: Schritt 3, Bild 1 von 1
    • Remove top left and top right screws.
  4. Apple Powerbook 520/540 General Disassembly: Schritt 4, Bild 1 von 1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: Schritt 5, Bild 1 von 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Apple Powerbook 520/540 General Disassembly: Schritt 6, Bild 1 von 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: Schritt 7, Bild 1 von 3 Apple Powerbook 520/540 General Disassembly: Schritt 7, Bild 2 von 3 Apple Powerbook 520/540 General Disassembly: Schritt 7, Bild 3 von 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Mark McNeff
497 Reputation
2 Anleitungen geschrieben
2 Kommentare
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Antwort
Thanks been trying to fix this for a long time
Luke - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 48
Insgesamt: 6,684
