Was du brauchst
Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
Remove this screw using a Phillips #00 screwdriver.
Rotate the camera to find the side panel with the lanyard attachment.
Detach the side panel by the lifting bottom corner slightly with the spudger.
Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
On back of LCD screen, locate the three screws underneath the ribbon and remove them.
Take out rectangular component on the side where the screws were.
Pry apart screen from back casing using the spudger.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
