Zum Hauptinhalt wechseln
HTC HD2 Vibrator Replacement
Was du brauchst
  1. HTC HD2 Vibrator Replacement, Battery: Schritt 1, Bild 1 von 1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Vibrator Replacement: Schritt 2, Bild 1 von 2 HTC HD2 Vibrator Replacement: Schritt 2, Bild 2 von 2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Vibrator Replacement, Midframe: Schritt 3, Bild 1 von 2 HTC HD2 Vibrator Replacement, Midframe: Schritt 3, Bild 2 von 2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Vibrator Replacement: Schritt 4, Bild 1 von 2 HTC HD2 Vibrator Replacement: Schritt 4, Bild 2 von 2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Vibrator Replacement, Vibrator: Schritt 5, Bild 1 von 2 HTC HD2 Vibrator Replacement, Vibrator: Schritt 5, Bild 2 von 2
    • Set the phone down on its screen.
    • Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
  6. HTC HD2 Vibrator Replacement: Schritt 6, Bild 1 von 1
    • Pull the vibrator motor from the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 24-55, Amido Spring 2011 Mitglied von Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 5,751
