Was du brauchst
Remove the back cover to access the battery. Press the tab on the bottom of the cover.
Slide the back cover downwards off of the phone while pressing the tab down.
Locate the bottom-left corner of the phone where there is a spot to remove the battery.
Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
Take off the casing and keyboard.
Remove the screws while holding the screen in place using a Torx T6 screwdriver.
Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
Lift the ribbon off of the contact with the motherboard.
Gently pull the screen off of the phone.
Be sure not to rip the sticker that connects the display and the motherboard.
Pull the silver case off to completely free the cracked or damaged screen.
Remove the connector housing by pushing and sliding it off the back panel.
After the Connector Housing has been removed, there is nothing else holding the Microphone in place. Simply remove if from the housing by pulling up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
