Einleitung
Before you begin, make sure the device is off. You will need to use the screen replacement guide as a prerequisite.
Was du brauchst
Use a plastic opening tool to pry the screen up in the right hand corner.
Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
Begin by locating the double sided pull tape locations.
Pull the black soft tabs to release the tape's adhesion.
Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
After the battery is totally free of any adhesion, simply lift the battery from the case.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
ctgblue -
How do you know if ita battery or charging port? Mine dont do anything whe. Its
