Zum Hauptinhalt wechseln
Amazon Fire HD 10 Battery Replacement
Was du brauchst
  1. Amazon Fire HD 10 Battery Replacement, Screen: Schritt 1, Bild 1 von 3 Amazon Fire HD 10 Battery Replacement, Screen: Schritt 1, Bild 2 von 3 Amazon Fire HD 10 Battery Replacement, Screen: Schritt 1, Bild 3 von 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Battery Replacement: Schritt 2, Bild 1 von 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Battery Replacement: Schritt 3, Bild 1 von 2 Amazon Fire HD 10 Battery Replacement: Schritt 3, Bild 2 von 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Battery Replacement, Battery: Schritt 5, Bild 1 von 3 Amazon Fire HD 10 Battery Replacement, Battery: Schritt 5, Bild 2 von 3 Amazon Fire HD 10 Battery Replacement, Battery: Schritt 5, Bild 3 von 3
    • Locate the power cable that links the battery to the motherboard.
    • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
    • The third image shows what it should look like with the battery power cable is disconnected.
  6. Amazon Fire HD 10 Battery Replacement: Schritt 6, Bild 1 von 3 Amazon Fire HD 10 Battery Replacement: Schritt 6, Bild 2 von 3 Amazon Fire HD 10 Battery Replacement: Schritt 6, Bild 3 von 3
    • Begin by locating the double sided pull tape locations.
    • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
    • Pull the black soft tabs to release the tape's adhesion.
    • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
    • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
  7. Amazon Fire HD 10 Battery Replacement: Schritt 7, Bild 1 von 3 Amazon Fire HD 10 Battery Replacement: Schritt 7, Bild 2 von 3 Amazon Fire HD 10 Battery Replacement: Schritt 7, Bild 3 von 3
    • Make sure all the adhesive is removed before trying to lift the battery from the case.
    • After the battery is totally free of any adhesion, simply lift the battery from the case.
  8. Amazon Fire HD 10 Battery Replacement: Schritt 8, Bild 1 von 3 Amazon Fire HD 10 Battery Replacement: Schritt 8, Bild 2 von 3 Amazon Fire HD 10 Battery Replacement: Schritt 8, Bild 3 von 3
    • Inspect battery for any leakage.
    • Please follow all U.S. regulations and laws when disposing or recycling the battery.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Jaie Hillery
1.718 Reputation
10 Anleitungen geschrieben
USF Tampa, Team 16-6, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Mitglieder
22 Anleitungen geschrieben
8 Kommentare
why is there so much empty space next to the battery?
echow2001 - Antwort
Big screen, little processor. The screen dictates the space, that’s why the battery has to be secured with adhesive.
ctgblue -
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
tyger.night - Antwort
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
ctgblue -
How do you know if ita battery or charging port? Mine dont do anything whe. Its
Tech Reviews - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 102
Letzte 30 Tage: 517
Insgesamt: 41,785
