Zum Hauptinhalt wechseln
Nikon Coolpix AW130 Shutter Button Replacement
Was du brauchst
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: Schritt 1, Bild 1 von 2 Nikon Coolpix AW130 Shutter Button Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix AW130 Shutter Button Replacement: Schritt 2, Bild 2 von 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: Schritt 3, Bild 1 von 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix AW130 Shutter Button Replacement: Schritt 4, Bild 2 von 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: Schritt 5, Bild 1 von 2 Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: Schritt 5, Bild 2 von 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix AW130 Shutter Button Replacement: Schritt 6, Bild 2 von 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: Schritt 7, Bild 1 von 2 Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: Schritt 7, Bild 2 von 2
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: Schritt 8, Bild 1 von 3 Nikon Coolpix AW130 Shutter Button Replacement: Schritt 8, Bild 2 von 3 Nikon Coolpix AW130 Shutter Button Replacement: Schritt 8, Bild 3 von 3
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Lauren Stepp
1.251 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,078
