Zum Hauptinhalt wechseln
Palm Zire 71 Battery Replacement
Was du brauchst
  1. Palm Zire 71 Battery Replacement, Preparation: Schritt 1, Bild 1 von 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Battery Replacement, Top Screws (2) Removal: Schritt 2, Bild 1 von 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Battery Replacement, Bottom Screws (3) Removal: Schritt 3, Bild 1 von 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Battery Replacement, Front Panel Removal: Schritt 4, Bild 1 von 2 Palm Zire 71 Battery Replacement, Front Panel Removal: Schritt 4, Bild 2 von 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: Schritt 5, Bild 1 von 2 Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: Schritt 5, Bild 2 von 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Battery Replacement, Back Cover: Schritt 6, Bild 1 von 2 Palm Zire 71 Battery Replacement, Back Cover: Schritt 6, Bild 2 von 2
    • Slide the back cover off.
  7. Palm Zire 71 Battery Replacement, Battery: Schritt 7, Bild 1 von 1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Battery Replacement: Schritt 8, Bild 1 von 2 Palm Zire 71 Battery Replacement: Schritt 8, Bild 2 von 2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Battery Replacement: Schritt 9, Bild 1 von 3 Palm Zire 71 Battery Replacement: Schritt 9, Bild 2 von 3 Palm Zire 71 Battery Replacement: Schritt 9, Bild 3 von 3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Battery Replacement: Schritt 10, Bild 1 von 3 Palm Zire 71 Battery Replacement: Schritt 10, Bild 2 von 3 Palm Zire 71 Battery Replacement: Schritt 10, Bild 3 von 3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Jinxian Jiang
245 Reputation
3 Anleitungen geschrieben
CSU Los Angeles, Team 1-5, Nelson Spring 2011 Mitglied von CSU Los Angeles, Team 1-5, Nelson Spring 2011
CSULA-NELSON-S11S1G5
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 58
Insgesamt: 9,043
