Zum Hauptinhalt wechseln
Flip MinoHD Casing Replacement
Was du brauchst
  1. Flip MinoHD Casing Replacement, Casing: Schritt 1, Bild 1 von 2 Flip MinoHD Casing Replacement, Casing: Schritt 1, Bild 2 von 2
    • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
    • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
  2. Flip MinoHD Casing Replacement: Schritt 2, Bild 1 von 2 Flip MinoHD Casing Replacement: Schritt 2, Bild 2 von 2
    • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
    • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
    • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
    • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 598
