Sony Cyber-shot DSC-W800 LCD Screen Replacement
  1. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: step 1, image 1 of 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: step 1, image 2 of 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: step 1, image 3 of 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 2, image 1 of 2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 2, image 2 of 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 3, image 1 of 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 3, image 2 of 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 3, image 3 of 3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 5, image 1 of 1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: step 6, image 2 of 2
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
3 other people completed this guide.
Thomas Campo
788 Reputation
4 Guides authored
USF Tampa, Team 17-5, Blackwell Winter 2016 Member of USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 2,436
