Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W800 LCD Screen Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: Schritt 1, Bild 3 von 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Thomas Campo
788 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 17-5, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 2,442
