Einleitung
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the LCD Screen:
- The LCD Screen is an integral part of the device and any improper handling can cause issues in other parts of the camera.
- Be cautious when removing ribbon wires.
- Be sure to keep track of all pieces that are taken apart.
Was du brauchst
Using the Spudger, remove the back panel from the device.
The loose piece circled in the picture will most likely fall off the camera housing.
Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
Lift the back panel and separate the LCD Screen by prying it up.
Remove the back panel.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
