Zum Hauptinhalt wechseln
Kyocera Hydro Vibe SIM Card Replacement
Was du brauchst
  1. Kyocera Hydro Vibe SIM Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe SIM Card Replacement: Schritt 2, Bild 1 von 3 Kyocera Hydro Vibe SIM Card Replacement: Schritt 2, Bild 2 von 3 Kyocera Hydro Vibe SIM Card Replacement: Schritt 2, Bild 3 von 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe SIM Card Replacement, SIM Card: Schritt 3, Bild 1 von 1
    • Locate the SIM card indicated by the arrows and picture.
  4. Kyocera Hydro Vibe SIM Card Replacement: Schritt 4, Bild 1 von 2 Kyocera Hydro Vibe SIM Card Replacement: Schritt 4, Bild 2 von 2
    • Use the precision tweezer set to safely remove the SIM card.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 623
