Zum Hauptinhalt wechseln
Canon EOS 30 lnner Eyepiece Replacement
Was du brauchst
  1. Canon EOS 30 lnner Eyepiece Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 lnner Eyepiece Replacement: Schritt 2, Bild 1 von 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 lnner Eyepiece Replacement: Schritt 3, Bild 1 von 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 lnner Eyepiece Replacement: Schritt 4, Bild 1 von 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 lnner Eyepiece Replacement, Top Panel: Schritt 5, Bild 1 von 1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 lnner Eyepiece Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 lnner Eyepiece Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 lnner Eyepiece Replacement: Schritt 8, Bild 1 von 2 Canon EOS 30 lnner Eyepiece Replacement: Schritt 8, Bild 2 von 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 lnner Eyepiece Replacement, The Inner Eyepiece: Schritt 9, Bild 1 von 1
    • Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
  10. Canon EOS 30 lnner Eyepiece Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 4.3 mm silver screws on each side of the inner eyepiece.
  11. Canon EOS 30 lnner Eyepiece Replacement: Schritt 11, Bild 1 von 1
    • Separate the inner eyepiece into three parts.
    • The outer piece (left) has a small gear, which can easily fall off and get lost.
  12. Canon EOS 30 lnner Eyepiece Replacement: Schritt 12, Bild 1 von 1
    • Remove the two 3.6 mm black screws from the outer piece.
  13. Canon EOS 30 lnner Eyepiece Replacement: Schritt 13, Bild 1 von 1
    • Remove the glass panel and replace it.
    • When removing the glass panel make sure not to separate the small rubber piece attached around the frame.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jackie
236 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 8-8, Regan Spring 2011 Mitglied von Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 3,096
