Einleitung
This guide will help you step by step to reach and replace the inner eyepiece of canon EOS 30.
Was du brauchst
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
