Zum Hauptinhalt wechseln
Nikon N2000 (F301) Battery Compartment Replacement
Was du brauchst
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: Schritt 2, Bild 1 von 1
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: Schritt 3, Bild 1 von 1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: Schritt 4, Bild 1 von 1
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 25-26, Garner Spring 2011 Mitglied von Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 31
Letzte 30 Tage: 148
Insgesamt: 17,219
