Zum Hauptinhalt wechseln
How to clean Nikon N2000 (F301) battery corrosion
Was du brauchst
    • In this guide we will be referring to 'left'and 'right' as though the camera's front (the part that says Nikon) facing you.
    • Use a quarter to twist open the one large screw on the bottom case. (No picture available.)
  1. How to clean Nikon N2000 (F301) battery corrosion: Schritt 2, Bild 1 von 1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  2. How to clean Nikon N2000 (F301) battery corrosion: Schritt 3, Bild 1 von 1
    • Your camera should look something like this.
    • Clean the marked areas with a cotton swab soaked in CLR or vinegar.
  3. How to clean Nikon N2000 (F301) battery corrosion: Schritt 4, Bild 1 von 1
    • Corrosion appears as the bluish build-up you see in this picture. Scrub with a cotton swab until it has visibly decreased.
  4. How to clean Nikon N2000 (F301) battery corrosion: Schritt 5, Bild 1 von 1
    • All cleaned up!
Abschluss
Reinsert the batteries by following the instructions backwards. If it's still not getting power, head over to our battery compartment replacement guide. Note: It may be tough to find replacement parts.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 25-26, Garner Spring 2011 Mitglied von Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Wow it working thanks for assisting me. I used vinegar to clean my camera so it working now
lazarusmolai - Antwort
Thumb down! Step 5 says, “All cleaned up!” But the picture shows much corrosion still present. Asking for further problems! Look up: "Nintendo Gameboy Pocket Shell-Side Battery Terminal CorrosionRemoval” for tips how to do it more thoroughly.
Wolf Naegeli - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 71
Insgesamt: 15,655
