Zum Hauptinhalt wechseln
Apple PowerBook G3 400 Keyboard Replacement
  1. Apple PowerBook G3 400 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Apple PowerBook G3 400 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Apple PowerBook G3 400 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Your computer should look approximately like this.
Abschluss
Byron Hoefer
70 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 4-2, Regan Spring 2011 Mitglied von Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 1,772
