Zum Hauptinhalt wechseln
HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement
Was du brauchst
  1. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Remove Back Panel: Schritt 1, Bild 1 von 1
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Remove Inner Back Pannel: Schritt 2, Bild 1 von 2 HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Remove Inner Back Pannel: Schritt 2, Bild 2 von 2
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Remove Upper Portion: Schritt 3, Bild 1 von 2 HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Remove Upper Portion: Schritt 3, Bild 2 von 2
    • Press down on the two plastic hinges to remove the upper portion of printer.
  4. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Unplug Speaker Wire: Schritt 4, Bild 1 von 1
    • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
  5. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Removing Scanner Tray: Schritt 5, Bild 1 von 2 HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Removing Scanner Tray: Schritt 5, Bild 2 von 2
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward to release the tabs from the printer.
  6. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Removing Scanner Tray - cont.: Schritt 6, Bild 1 von 1
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
  7. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement: Schritt 7, Bild 1 von 1
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement: Schritt 8, Bild 1 von 1
    • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. HP PSC 2410 Photosmart All In One Printer Scanner Tray Replacement, Detaching the Scanner Tray: Schritt 9, Bild 1 von 1
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Angehängte Dokumente
Cody Long
153 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-31, Maness Spring 2011 Mitglied von Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 5,774
