Einleitung
Use this guide to replace a broken LED bulb in a Light Angel motion activated LED. Disassembling the device requires a Phillips screwdriver and a plastic opening tool. Replacing the LED bulb requires knowledge of soldering. For users with basic soldering experience, this project will take about 30 minutes.
Was du brauchst
Using a plastic opening tool, remove the base of the Light Angel.
Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
Locate the faulty light emitting diode on the back of the circuit board.
Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
Insert the new light emitting diode through the two holes left from removing the old one.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
