Zum Hauptinhalt wechseln
Samsung Impression Antenna Replacement
Was du brauchst
  1. Samsung Impression Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Antenna Replacement: Schritt 2, Bild 1 von 2 Samsung Impression Antenna Replacement: Schritt 2, Bild 2 von 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Antenna Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Antenna Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Antenna Replacement, Circuit Board: Schritt 5, Bild 1 von 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  6. Samsung Impression Antenna Replacement: Schritt 6, Bild 1 von 2 Samsung Impression Antenna Replacement: Schritt 6, Bild 2 von 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
  7. Samsung Impression Antenna Replacement, Antenna: Schritt 7, Bild 1 von 2 Samsung Impression Antenna Replacement, Antenna: Schritt 7, Bild 2 von 2
    • Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
    • The antenna assembly will snap off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Saul Villatoro
255 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 8-10, Regan Spring 2011 Mitglied von Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,864
