Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W800 Button Board Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: Schritt 1, Bild 3 von 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-W800 Button Board Replacement: Schritt 2, Bild 2 von 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-W800 Button Board Replacement: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-W800 Button Board Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Thomas Campo
788 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 17-5, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Mitglieder
5 Anleitungen geschrieben
4 Kommentare
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Antwort
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Antwort
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 2,351
