Einleitung
We will remove the display from the Garmin watch so it can be replaced. Tools that you will need include nylon spudger and Torx T9 screwdriver.
Was du brauchst
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
